RE: HELP PLEASE
Instead of buying a new motor, you may want to just get a new piston kit for it. its alot cheaper, and may very well be the issue you're having. So a rebuild will probably fix it. If you pull the engine over and it turns over easily, its probably worn out. There should be some distinctive resistance and a nice pop every revolution.
