RE: Sky Fly by Fly Zone
Could you use Du-Bro .047" push rods instead of the .032"? Would they not
have less flex & more strength?
I just converted the .047" in my Wing Dragon, plus the E-Z connectors on the
servo ends, rudder & elevator. They do make for quick & easy adjustments.
The Wing Dragon mfg. uses the .047" stock. What I also like about the Du-Bro
pushrod kit is the plastic sleeves that goes around the wire. Less friciton & binding.
