RE: Pull Pull Slack
you should check to make sure these wires arn,t cutting into some wood sections somewhere in the fuselage or where they exit. normally when these wires are crimped and tensioned they stay tight, if in doubt you should replace these with my favourate wire which is nylon coated fishing wire trace plus the crimps are long and strong.
