RE: Kevlar
Get a crow foot weave Kevlar, The plain weave can be hard to get around tight radius corners, Regular good quality scissors work fine for cutting Kevlar, in fact a cheap pair will work , you just need to run the blades on a grinder 90 degrees to the blade to give the blade some tooth so the kevlar won't slip out while cutting, do a search on google for Cutting Kevlar fabrics.
