temp readings???
i loop the onboard probe right where the sink meats the top of the cylinder. This spot should give you very accurate readings with your onboard Viper etc guage. I think the highest reading Ive taken is 230ish on sirio .18 and thats probably the best spot to record the highest temp from. btw.. the venom only differed around 5 degrees from the raytek when tested once.
Lampeye
