RCU Forums - View Single Post - Engine Specs Please Help!
Old 10-07-2002 | 07:13 PM
franknl
Default Engine Specs Please Help!
Fiery
Can you give me some more info on which carbs will fit an SC 46? I have one with rear needle. It works ok, but I have trouble tuning it at the bottom end. One problem may be that my fuel tank is slightly low (top of tank is at approx. needle height), but I can not get it any higher....
Someone adviced me to get another carb, and I am willing to give that a try. The carb that came with the engine does not fill me with confidence, the barrel can be moved slightly in and out, which makes me think that if the engine vibrates while running the bottom end may be adjusting itself constantly
Any info on replacement carbs would be appreciated!
thanks
FrankNL
