From what I have measured the wing/stab are very close to 0-0, or maybe 0 wing and a little + on the stab. I would say what you are seeing is probably right, depends on how accurately you did the measurements. Its tough to set the stab exactly at zero with the fully movable elevator.
I didn't check the other alignments.....the plane flew great out of the box so no need.
ORIGINAL: Brenner
Exactly what are the factory settings for wing & stab incidence? Out of the box mine had the stab at 0 degrees and the wing at -0.3 degrees.
I'm comfortable with the stab, but I have my doubts about the wing. Also, while the stab was aligned with the wing laterally it was 95 deg/ 85 deg with respect to the rudder. Oh, and before I forget, the rudder was twisted as well, about 3 mm from top to bottom.
