RCU Forums - View Single Post - 20 min. hover
Old 05-29-2008 | 01:57 AM
funflier
Default RE: 20 min. hover
thats the giveaway that the motors are gone is when the little Llama won't lift off due to low rpm. You dont hear it but it only has to drop off a little. This is only true if your battery is fully charged. You may want to check the peak voltage on your battery after charging it. Should be about 8 - 8.4 volt.
