RE: Sig Kadet Senior wing struts?
Balsa will be plenty strong enough.
I like to build blocks into the wing and attach the struts with pinned hinges (Either the flat type screwed into the wing, or the Robart type glued into the wing)
On the fuse end you can just use a piece of thin aluminum with a hole in it to screw into the bottom of the fuse
