RE: Composite-ARF Integral, kinda build thread
Hi
Jason I notice that you have moved you CG to 175 mm from LE ..... i know this is personal preferences but it seems that i have mine at 195 and alomst same mix but not that much rudder to ail ...and the ke when i have left wing up need more elevator input than the other!
When you have the CG at 175 yoy didnt find the plane a bit jumpy on elevator inverted?
