RE: Bind plug when buying a Radio?
Spektrum air rx's use binding plugs. There are two different types of binding plugs. One goes into a charge port, and the other goes into a channel on the rx. The charge port is more convenient, but you have to have a three wire switch setup for it to work. Otherwise, you have to use the one that plugs directly into the rx.
