RCU Forums - View Single Post - Hacker A60-24S mount recommendation
Old 05-29-2008 | 05:11 PM
elan120
Default Hacker A60-24S mount recommendation
Can anyone suggest the mounting method for the A60-xxS motor? Hacker recommend using their cage mount, but since the weight is almost 7 oz, I wounder if there are lighter mounting methods available. I was thinking making my own out of CF-Balsa laminates, but not sure what is the correct size bearing I should use to support the back, if the rear support is needed.
TIA,
Kevin
