RE: MVVS Twins
Rosh . the mvvs twin i have doesn't have the walbro carb so i can assume it is a 1.2 ? is there any other way to tell what size it is ? i have the glow mufflers that came with it but it was converted to gas as it has spark lugs steel mufflers and a electronic ignition. it doesn't look like it has ever been started. So the question will the stock glow carb work for the gas conversion ? if not what mods does it need to run on gas. do you know where i can get any of the orignal documentation for it ?
