RE: 1/3 Scale Nieuport 11
Scott, aside from mixing the fuel there isn't anything different than running gas and a EI except you get more RPM's. It seems to be the best way to get the most performance from these gas 4-strokes and without the expense of an EI. I am using 33% nitro for cars which has a very low oil content and the B&S 4-stroke has a wet sump oil system so no other oil in the fuel. It's really a pretty clean solution. A quart of the 33% nitro is $14. and will last for quit awhile mixed with the gas. Your Nieuport is looking good.
