RCU Forums - View Single Post - Engine upgrade for Super Skybolt ARF?
Old 05-31-2008 | 04:36 AM
da Rock
Default RE: Engine upgrade for Super Skybolt ARF?
My Skybolt has just under 9" from the shaft to the ground.
It's gear isn't the stiffest you'll find on most 8-10lb models. If you land with the prop turning, you need to consider gear flex. Over the years, my gear has relaxed a number of times and needed straightening.
I fly off of grass mostly. That's probably a 13x6 prop in the picture. (Picture taken back in 2006.) It's got how much clearance?
All the props I fly on that airplane show grass stains.
That's an OS61FX on the airplane. Gives really good vertical.
