RCU Forums - View Single Post - Problems Getting My Brushless Setup To Work HELP!!!
Old 05-31-2008 | 01:57 PM
Humphry1969
Default Problems Getting My Brushless Setup To Work HELP!!!
O.K everybody you've never steered me wrong in the past and hopefully someone can help me now.I recently purchased a Feigao 8L and a Castle Creations Hydra 120 ESC.After installing them in my boat and running through the calibration mode to sync up with my radio system I got the "Two Beep" signal indicating "successfull arming" as per the instructions.Unfortunetly the motor does not work.When I pull the throttle the motor shaft "dances" back and forth and beeps but nothing else.Everything else works fine I.E. steering.As per the "Trouble shooting" instructions I tried the calibration mode multiple times with no luck.The ESC keeps saying everything is armed and ready but the motor does not work.I own other brushless setups and have never run into any problems so I am at a loss.Is there a way to test the components seperately to see if one or the other is faulty,or do you think its just "operator error".Both the motor and ESC were purchased from reputable dealers.I have also tried different radio sytems of mine to no avail. Any help would be greatly appreciated!
