RE: New Losi 8ight T, Servo Flop, couple questions please
INTEGRA..It's nice to see you so loyal to your brand..but their was and to a point still is a problem with the throttle/radio tray..I have run quite a few different Truggies, Buggies, 1/10 scale and 1/8 scale on road cars..I have never had servo problems like I did with the Losi..and I'm not the only one..at first I did see some of the Losi factory pros's having problems with the throttle servos..Their are fixes and their is a lot of info on this problem..or as you put..non problem..Once I used the rubber gromets (the ones that come with your servo)..If fact i now use the rubber grommets with every throttle servo.. I never had anymore problems..ever..I do know how to set my end point adjustments and I do know how to set up my throttle linkages..I just think that for you to assume that no one knows how to set their end points or adjust their linkages is wrong..
