RCU Forums - View Single Post - Interested in electric pattern
Old 06-01-2008 | 11:43 AM
shannah
Default RE: Interested in electric pattern
Hello Enrique,
There are a lot of ways to go. The best thing to do is to read the many informative posts on this website. You will get a feeling for the different products. First, you will have to decide which electric motor type you want to run. Hacker C50 inrunner type, or outrunner (dualsky, hacker, axi, plettenberg). The outrunner is lower cost and offers good performance.
Then you will need to select the matching ESC. The Jeti Advance OPTO 90 is a good first choice for most outrunners and is fairly inexpensive.
You will need a charger and balancer. The Thunderpower 1010 charger and Thunderpower 210 balancer are the most popular products.
Lastly, you will need to choose your batteries. You will need 10s packs. For that, you should look for packs of at least 4500mah. 5000mah is a good size to look for. You can get the packs from many, many sources so you will need to shop around. For the 5000mah packs, don't get less than 17C discharge. Try to use 25C packs if you can.
Other than that, you can find just about all the information you need to compare products and find a solution which will work for you. There are several topics related to electric Impacts so that would be a good starting point.
Steve
