RCU Forums - View Single Post - the hyper st PRO thread!
Old 06-01-2008 | 03:15 PM
  #1137
supertib's Avatar
supertib
Default RE: the hyper st PRO thread!
ORIGINAL: jaywax
ORIGINAL: supertib
ORIGINAL: jaywax
ORIGINAL: supertib
there are 3 good reasons to change the Hyper tank... the mounting posts suck and allow too much flex which will cause fuel to foam, its very common to see air bubbles in the Hypers fuel line because its sucking foam....... 2nd reason is the tanks shape, its huge on top and very small on the bottom, which will cause the fuel pressure to change as the tank uses up its fuel, exactly what happens on a Savages fuel tank... The fuel pressure is idrectly related to the surface area of the fuel, more surface area means more pressure, less surface area means less pressure..... Which is why the best tanks are always square, the surface area stays constant from full to empty. The Mugen tank is square and holds very consistent fuel pressure.... You can tune around the Hyper tank( rich when full, lean when empty) just like you can with a Savage tank... but honestly why bother hassling when you can install a much better tank that will tune much more constantly from full to empty... As well the left side opening of the Hyper tank is ghetto and requires someone to hold the pipe side of the truggy to fuel the tank.... total PITA..its much easier to refuel with a standard front/back fuel tank....
Never had or heard of this problem. You may need to start up your own RC company and design your own tanks and engines. You are obviously smarter than the engineers and researches at these companies. You constantly criticize companies and their products when you have a problem. You are a freaking RC Genius.
OFNA and Hobao are very aware of these issues... some of their sponsored drivers are where I got my info from in the first place...the next gen Truggy will have these issues resolved....And definitely I am smarter then some of the engineers who design and develop these products... some of the crap that is produced is terrible and it doesn't take a genius to see that.....
There are no issues to report. No one I know has had these issues. No one on this thread had issues with the tank until Supertib Almighty purchased a Hyper ST Pro. No one had problems running a 21 in their ST until Supertib Almighty says it is too heavy. Dude, every thread you join you try to become the expert. This is not my opinion, it is a fact. You can click on your screen name and look at all your posts. They are all criticizing some well know product. I'm just sick of you.
Too bad for you then !
