ORIGINAL: christian_oele
Hi Isaac,
thanks for reply.
The T-Canalizer is on the canopy.
Do you realy think that the position of the T-canalizer has so much effect to the C.G. ?
Also knowing that C.G. position is of personal preference, 20mm difference as we have, seems for me to be very much ...
Regards,
Christian
Hi christian
Divergence of 20mm of the C.G. is very common, in the plan of the Oxalays (and other plans) the divergence of C.G. is 20mm.
There are so many variants that has influence on the C.G. location. For example, the distance between the wing and the stabilizer,
I think that in the ARF version of the Osmose the distance between the wing and the stabilizer is about 10mm shorter than what was marked in the mold.
Also in my Osmose the incidence of the wing is different from what was marked in the mold (see picture).
Regards,
Isaac Najary
