RE: help with wiring everything
if the power switch is off....then wouldn't it not be draining while charging? if i don't even have to take off my inespection hatch to charge the battery, then that's just a plus....because i'll thot about a solar panel charging too....when im in the dreaded sun, i could keep the boat topped when im not using it...etc. i mean, if that would work....i don't want to damage the battery or anything.
i like the idea of having a power switch for some reason. i know it's all in my head.
i need two servos because one is for the rudder... and the other one is for the fish food hopper...it will release the trap doors so the food drops into the water.
so deans connectors is the ticket it sounds like....should i use those instead of the bullet connectors on the motor too?
instead of the led switch wires directly going to the battery terminals, id like for another dean connector....so i guess id have to make a three way dean connector, one to the ESC and then to the LED switch....and then the last one goes to the battery terminals. not sure if that would work thou?
