RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 06-04-2008 | 10:15 AM
  #1894
frieshoo's Avatar
frieshoo
My Feedback: (20)
Default RE: DL-50 engine
ORIGINAL: salerno
hey, i just noticed on my dl-50 where the crankcase halves join, there is a little fuel that comes out on case. engine is still running fine but will it start to run crap? does it matter. is there potential for tuning problems? should i pull the motor apart and fit new gaskets?
If raw fuel is present, and it's not coming out of the carb... you could have a problem down the road.. with an air leak.. and problems running.. because the engine will not pump the carb correctly.
I would find out where the fuel is coming from... Make sure all the bolts are tight...
Is it raw fuel? burnt fuel?
