RCU Forums - View Single Post - Gst 7.7 wont start
Old 06-04-2008 | 12:12 PM
burningpoo's Avatar
burningpoo
Default RE: Gst 7.7 wont start
ORIGINAL: delray226
I dont know what kind of one way or check valve i should put in or where to get one, and i imagine its supposed to go between the cell and the engine.
Any hobby store can order/have one already, ofna has a one way check valve, it's what most of us used. NOT between the tank and engine, from the exhaust TO the tank, with the air flow going into the tank. This way the pressure can't excape when you let off the gas, takes away the lean issue. Before I did this I had to run the tank from full to half and refill or retune. The stock tank looks like someone took 2 tanks and made 1. It's fat on top and once it meets the frame it's about half as wide.
Glad to hear everything worked out for you. Hope it's in your hands soon.
ID:	963549   Click image for larger version
