RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 06-04-2008 | 02:46 PM
  #1899
dogshome's Avatar
dogshome
Default RE: DL-50 engine
A millimeter on each one. I used a needle file and took them closer together by 1mm each. With the stainless header there is enough room to do that, if it was an aluminium one you might not get the screw heads in.
This (with the carb into the fuz) passes our UK test which is 82dB(a) at 7 metres.
