ORIGINAL: jetmech05
I've never seen a pull pull set up with the servo off of center...seems like one side would be real slack when the contol surface was moved to the longer cable side......
Its ok you cant push with a cable anyways as long as there both tight at center what the none pulling cable does when the other is under tension is of no importance.
Steven
