ORIGINAL: KC36330
as long as it'll stay mixed into the Kero it's fine. mix some in a small container and let it sit a day or so and see if you have any separation.
I think he wants to use it in glow-fuel.
If that's the case, some is okay, some is not I'm thinking that the newer (version 2) oil has problems.
Also be aware that this stuff can have some pretty toxic combustion byproducts and I believe it also stains film/paint.
A better option would be the DTE Lite turbine oil. I think it's an Ester-based biodegradable turbine oil that should mix with methanol (but you'd need to confirm that).
