RC Fuels Nitromethane, Castor Oil, Synthetic, heli fuel, 4 stroke, etc...Fuel Q&A is here!
Turbine Engine Oil
Old 07-21-2008 | 10:45 AM
blw's Avatar
blw
Default RE: Turbine Engine Oil
ORIGINAL: Sport_Pilot
What is tick over?
A term usually meaning a nice, slow idle. "Ticking over" means idling.
Old 07-21-2008 | 12:37 PM
Sport_Pilot's Avatar
So improve idling? Well OK acetone does nothing for that, it actually makes the needle more sensitive. Nitro makes the needle less sensitive, but once adjusted right a 0% nitro fuel engine will "tick over" just as nicely.
Old 07-21-2008 | 02:15 PM
Yes I will run this engine for a few flights and then tear it apart to have a look. I haven't been out flying lately due to crappy weather and other life commitments.
I used 15% turbine oil and 2% castor oil.
I did not think the needles were more sensitive with this fuel. We adjusted the low speed needle an 1/8 of a turn at a time just like we did with the 10% nitro fuel and the high speed till the engine leaned out and slowed down and then we richened it up a bit to our liking.
The compression is raised in the engine, but I cannot tell you by how much because I do not know. I had the head machined so the squish band was .010" from the piston at TDC instead of the stock .016"
Everything I read pointed towards acetone helping with the idle, that's why I used it, but according to what I read it does nothing for the top end.
Mark
Old 10-12-2008 | 06:13 PM
how does it smell... like burned A1?
Old 10-12-2008 | 09:12 PM
It's funny you should ask that question because this fuel has a real distinct smell to it in the jug and cleaning the excess off the plane after a flight. If you open a box of band aids the smell you get from inside the box is what the spent oil smells like when I am cleaning off the plane.
The fuel in the jug has a strong odour to it, but it doesnt remind me of anything like the spent oil does.
Mark
Old 10-13-2008 | 07:13 AM
  #31
is there any way to make normal 5% mix smell like burned A1? i love that smell lol
Old 10-13-2008 | 03:06 PM
  #32
Banned
You can buy fuel-scent in lots of different "flavors" (grape, vanilla, cherry, etc) and I always wondered why they didn't do a "castor" or "Jet-A1" scent.
Old 10-13-2008 | 04:10 PM
  #33
cool [8D]
thanks...
