RCU Forums - View Single Post - Pershing Jerky Movement?
Old 06-04-2008 | 11:49 PM
blitzkrieg65's Avatar
blitzkrieg65
Default RE: Pershing Jerky Movement?
ORIGINAL: skitt
HI All,
New guy to the forum, so my apologies if this has been covered somewhere.
Got my first Heng Long Pershing today and I love it! Everything seems to work ok, except for jerky movement, kinda of a stop and go action. Very touchy movements with the transmitter in any direction I go,not bad....just real touchy IMO. I even put it on my desk and ran the tank full speed and it acts like something was loose, it stops briefly and goes, very quickly. The turret,BB gun,smoke, and sound all seem to work as advertised. is this a crystal problem or something loose inside the tank? How do you tell the difference? And if I do take it apart, whats the way to proceed in taking it apart? Has anyone posted pics of taking it apart? I didn't spot anything when I searched the forum. Thanks for any help in advance....
Skitt [:@]
Wackyheels I think has a manual in the FAQ section or else try tankzone, but the Pershing is just eight screw on the bottom! The Jerking could be anything from the new tracks not broken in and the flash is catching, or the tracks are rubbing on the skirt when you make certain movements I have had a couple of Pershing here I needed to use heat gun to fix the mold problem! Or it could be a loose antenna or connection to the receiver board! Everyone buying a Heng Long should open them up first and look for cold solder and wires about to fall off and scews loose on the gear box ect... If you do the PM they will run great!
The blitz
