RE: Scratch Build - 29" Balsa Stepped Cat
I use a scroll saw for cutting all the wood I use for boats. Works perfect. A little tip on cutting out your parts...I always cut a little oversize and sand the rest. Then, if there is a matching peice, clamp together and sand until it is the same.
