RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 06-05-2008 | 09:08 PM
  #1905
nmking09's Avatar
nmking09
My Feedback: (61)
Default RE: DL-50 engine
Dont' remove the throttle spring. If needed, clip it, but do not fully remove it otherwise your butterfly valve will eventually wear out, and you will be needing a new carb. With the spring removed the valve vibrates against the carb walls and wears out.
