RCU Forums - View Single Post - Pershing Jerky Movement?
Old 06-05-2008 | 11:44 PM
skitt's Avatar
skitt
Default RE: Pershing Jerky Movement?
ORIGINAL: blitzkrieg65
ORIGINAL: skitt
Whats an alice track?
These are "alice tracks" they are backards, but mine is such a good runner I don't want to fix something that isn't broken!
The Blitz
Your problem, sometimes you have to widen the pins in the crytal both in the radio and in the tank (receiver board)! Is the antenna in the radio screwed in correctly? Do you have the antenna up all the way,, is there a large power source near by?
Ok, Think I found the problem.....One of the red wires running to the switch came loose, it was barely hanging on. Unfortunatly it seemed to short one of the boards cause it got smoking and I had to scramble to unplug the battery. Maybe too late now. Now i'm not sure if it was hooked to both parts of the switch or just one.
So to be clear, you can take the top off the tank and run it fine?
