RCU Forums - View Single Post - Engine Advice for my 30% SD/TOC Extra 260 87"
Old 06-07-2008 | 08:23 AM
soarrich's Avatar
soarrich
My Feedback: (98)
Default RE: 30% SD Models Extra 260 87"
SRpropTwister
You may want to stiffen up the firewall some too. My MT62 has a small footprint on the firewall and when I would go full throttle I could see the motor move 1/16' forward, I just thout that was odd untill the other day the aluminum corner brackets broke. This wasn't from engine shake, the MT62 is very smooth running, it was from firewall flex. I replaced the aluminum corner pieces with oak. I also replaced my gear with a set I had that where almost exactly the same, but 1/16 thicker aluminum. I fly from a very bumpy field though.
ID:	965541   Click image for larger version
