RCU Forums - View Single Post - Choosing the right one for a beginner
Old 06-07-2008 | 08:47 PM
OzMo's Avatar
OzMo
Default RE: Choosing the right one for a beginner
Hi again
saw your identical post in the beginers forum. you are asking for something rare or at least hard to get. So this is ok, we like to help new guys. I would strongly recomend you get a hitec or futaba 4 chanel radio. it will have all the stuf that goes into an airplane.
4 servos, battery, switch and has the charger for the airplane gear and transmitter. this radio will be fine for beginning and move on as you progress. If you are on your own in this you should learn to build AND REPAIR. a 2 meter power glider will do well to learn on.
a decent 4 chanel plane and a radio for 130 dollars is not likely to happen. good luck!
