RCU Forums - View Single Post - Need help with TJT 3000
Old 06-07-2008 | 10:20 PM
JET FX's Avatar
JET FX
Default RE: Need help with TJT 3000
ORIGINAL: CARS II
I need help with my TJT 3000, I got it not to long ago, today I had the chance to put it on a test stand, everything was going well 'till I try to start the engine, the Thermocouple is reading 236 degrees before I do anything and when I bring the throttle stick up to the top it goes into cooling mode, I see why it goes into cooling mode but, what's the deal with the temp. unit? [sm=50_50.gif] and where can I get a new one? ( this is a type "K" Thermocouple )
One other thing, I like to get the latest version for this FEDEC ( Gaspar ), where can I send it to have it updated?
Thank you in advance for any advice.
Sounds to me like you have a faulty thermocouple or possibly a FADEC problem.
The quickest way to resolve any potential TJT electronic component problem would be to ask Gaspar the designer of the FADEC systems used for the TJT-3000. You can contact Gaspar directly yourself here at Xicoy http://www.xicoy.com/
And the FADEC customer assistance forums http://www.xicoy.com/foros/index.php?board=7.0
You may also order any required electrical components including thermocouples and FADEC ECU's, fuel pumps, bearings etc via Xicoy.
Hope this helps
Cheers- Marty
