RE: 2 or 3 Line Fuel Tank Set Up
If you can access the pressure line at the muffler, use that line to fill the tank. Stand the plane on the spinner and if you think about it, close the intake window on the crank. Now simply gas it up until fuel spills out the carb. If you are a "neatness freak", just fill a pre-measured amount with a syringe.
