RCU Forums - View Single Post - Problems with short run time?
Old 06-09-2008 | 08:22 AM
i8tweety's Avatar
i8tweety
Default RE: Problems with short run time?
The number of winds is not the only factor when it comes to gearing. If the timing on the 19T that came with the truck is not as radical as a stock motor (24 degrees of timing advance), then it can pull a taller gear.
