Problems with short run time?
Ok so heres the deal, I have a Team Losi -T and i recently upgraded to a Epic 27turn motor. Ever since this upgrade the run times have been getting much shorter than with my previous motor. I don't think the problem lies with the batteries(they are less than a month old and i take good care of them), I think it might be the gearing on the car. It came stock with a 19 turn motor along with an 88 tooth spur & 20 tooth pinion. Would changing the pinion gear help this at all? Any help would be greatly appreciated.
RE: Problems with short run time?
Probobly would make a difference, higher gearing will keep the motor from winding out and reaching the rpms too fast which will drain the battery.
ORIGINAL: Super Mud
Check the motor after running for about 1 - 3 minutes, no longer.......see if the temp of the motor is too hot. At the same time check the temp of the esc. When you get those temps right or at least close you should be good to go AS LONG as you have good connections EVERYWHERE.
1 Post
There are a couple of things to look at. To start with, check your gear mesh (pinion/spur). If it is too tight, the motor will be working too hard, increasing motor heat and reducing run-time. If your gear mesh is ok, try going to a smaller pinion. Your top speed will be reduced, acceleration increased, and motor load reduced (increasing run-time).
One more thing: How much run-time were you getting with the factory 19T and with the 27T? What battery (capacity) are you using? What charger do you have?
yea there is no way that a higher tun motor should get lower run time with the same gearing... if its not the gear mesh, then it might be a bad motor....
CA
ORIGINAL: dacaur
1 Post
The number of winds is not the only factor when it comes to gearing. If the timing on the 19T that came with the truck is not as radical as a stock motor (24 degrees of timing advance), then it can pull a taller gear.
