RE: Skymaster L39 Builders???
sonicboom, when mounted per the instructions the side of the wings opposite the servo hole the servos are mounted on flexes. and thats with minimal pressure.
Oh and i left off the retracts were missing parts, hope skymaster usa can help with that, 22 ounces is what it took to balance even with the cg 130mm 5 mm back from recommended [:@], I really can't stand adding weight to a plane, Anyone else flying or seen one flying have any idea how much weight you had to add?
Kevin
BTW motor is moved as much forward as possible. the plane just limps to one side even with a screw.
