ORIGINAL: jaycey
Im sure this should be simple to fix...but its avoiding me so far!
I am trying to setup a 'spin' condition but when I flick the condition on, one of the elevator trims is changing.
I am using 2 elevator servos plugged into channels 2&5 (ailvator) I have gone into the trim menu and done the combined/seperate trim setup for the elevator channel but the servo plugged into channel 5 is still moving when I operate the condition.
Any ideas where I am going wrong?
Also I have setup a program mix for throttle to elevator. I have setup 2 program mixes to account for the 2 elevator servos, is there anyway of doing it with just one program mix?
Thanks in advance,
Jason
Hi, I use only one mix, no need to setup another one. What kind of mix have you turned on for the dual elevators? I use AILEVATOR and only one mix (* -> channel 2) is needed.
