RCU Forums - View Single Post - Hanger 9 Taylorcraft
Old 11-21-2002 | 02:01 PM
t-craft-RCU
Default Hanger 9 Taylorcraft
Hey Rick:
Sounds like you are enjoying your T-Craft! What size prop are you swinging on that G-23? You said you used the battery pack to balance; where did you locate it? I have a separate pack for my smoke and I'm not sure where I should mount it. I put the receiver pack on the left next to the gas tank under the dash. I have the smoke tank on the left next to the seat. Also, I was wondering if you used the blind nuts to mount your motor, or the regular bolts, washers and nuts. I put the latter in and I think I should pull them and put the blind nuts in. I'm sure the way it's set up now I'm going to have them come loose and it's a B#%@* to get in there to tighten them up. One more question...Did you go with the recommended control throws? 1 1/8" up and 1" down on the elevator, 2"on the rudder?
