RE: Rtf airplane battery problem
You need to make sure the VOLTAGE is the same, that is what you are concerned with, not the capacity. Mah is how much capacity the battery has and voltage is the power. If the voltage on the packs are the same and the pack is not to heavy you will be fine.
