RE: Rtf airplane battery problem
If it's very unpowered a larger battery won't do too much. You should also look into changing the motor maybe. Along with the larger battery , new prop, and probably a new esc may be needed. This might run you a couple of $$$ so ask yourself it's worth it for that plane.
Hope this helps
