RE: 9ZAP Condition Trim problems...
I am running several contitions on my 9Z, you should check the sub-trim programming by cycling between your contition switches. If the percentages are different by channel this will affect where your trims are in each condition. Everytime I make an adjust in the sub-trims, I have to adjust the condition as well.
Hope this helps!
Bill Holsten
Dist#2
