RCU Forums - View Single Post - 9ZAP Condition Trim problems...
Old 06-12-2008 | 08:42 AM
can773's Avatar
can773
Default RE: 9ZAP Condition Trim problems...
For the mix, there should be a LNK button on the bottom of the screen, right hand side I think (been a while since I was into my zap mixing screen!). That will pass the mix to the slave along to further mixed channels, like dual aileron and elevator. If you are not linked you will not get an arrow in the main screen.
In the main mix screen it should appear like this
THR ELE ->
That means you are linked to anything else mixed to the ele channel...which happens to be your other elevator
For the trim, as already stated, make sure ATV's/ sub-trims match across the conditions, also make sure your trims are set to CMB, and do not change when moving conditions.....if a trim is set to SEP it can change with conditions. If all that is good, then Mike is right......your radio needs service
ORIGINAL: jaycey
Im sure this should be simple to fix...but its avoiding me so far!
I am trying to setup a 'spin' condition but when I flick the condition on, one of the elevator trims is changing.
I am using 2 elevator servos plugged into channels 2&5 (ailvator) I have gone into the trim menu and done the combined/seperate trim setup for the elevator channel but the servo plugged into channel 5 is still moving when I operate the condition.
Any ideas where I am going wrong?
Also I have setup a program mix for throttle to elevator. I have setup 2 program mixes to account for the 2 elevator servos, is there anyway of doing it with just one program mix?
Thanks in advance,
Jason
