RCU Forums - View Single Post - the hyper st PRO thread!
Old 06-12-2008 | 03:45 PM
  #1234
spikeitaudi's Avatar
spikeitaudi
Default RE: the hyper st PRO thread!
ORIGINAL: darksoul242001
Anyone having problems with the diffs leaking? I've had nothing but bad luck with the rear diff. I've tried filling it up to a certain point where the gears are barely covered. I have checked the o-rings and diff cup seal and I still get the same results. My front or center do not leak but the rear does. I'm currently running 7k/10k/3k. Is there any other way to seal the diffs? I have lubricated the seals as well and have sealed the grub screw.
Yup. I used the Kyosho Diff Gasket and relubed and haven't had an issue since. The rubber o-ring between the crown gear and diff case is useless.
