RCU Forums - View Single Post - Wierd muffler FUJI
Old 05-10-2003 | 11:08 AM
Flypaper 2
Default Wierd muffler FUJI
Muffler is normal on older engines. On later ones they closed off the front. The plate on the side is to prime the engine for starting. Try opening the throttle wide open to prime with your finger over carb then go to idle. Tank may be to far behind engine for proper fuel draw tilting plane up or down. Hope this helps.
