RCU Forums - View Single Post - the hyper st PRO thread!
Old 06-12-2008 | 07:03 PM
  #1236
darksoul242001
Default RE: the hyper st PRO thread!
ORIGINAL: spikeitaudi
Finally got around to taking out my front and rear diffs due to them leaking. And boy did they leak. Both Empty. That red rubber band that seals the front and rear diff to the main gear is a joke. When taking it apart I compared it to my brother-in-laws Kyosho Inferno Buggy and guess what. The Front and rear diffs are identical down to every part. The thing about the Kyosho Inferno buggy diff is it also has a gasket inbetween the diff cup and the main gear. So I order it and it was a perfect fit. Cleaned out the diffs relubed put them back together plus the new gasket. So for anybody looking to fix the leak with the front and rear diffs here is the part I used.
[link=http://www.amainhobbies.com/product_info.php/products_id/4144]http://www.amainhobbies.com/product_info.php/products_id/4144[/link]
While we were at it my brother-in-law also fabricated some new gas tank posts as the stock ones just don't cut it. We made them alittle thicker and used small rubber orings to dampen the tank from vibration. Works like a charm.
Here are some pics of the new mounts.
After all the new mods went out for a test run and the mounts and new gaskets worked like a charm. Kudos to Jerzferno for making the new mounts.
Here was my orginal post Dark. It has the link to the gasket.
Hey thanks for the information I knew I had read about it before somewhere around here. I did order those gaskets. I had even tried the mugen ones because my LHS recommended them but they dont seem to seal right either. Are you still using the diff cup rubber ring or did you take that out and simply use the kyosho gaskets?
