RCU Forums - View Single Post - Where to run antenna wire?
Old 06-13-2008 | 10:26 PM
Jetdesign's Avatar
Jetdesign
My Feedback: (8)
Default Where to run antenna wire?
Does it matter if the antenna wire runs inside or outside the length of the plane? My instructions say to cut a hole in the side of the plane and run the antenna up to the top of the vertical stab. I'd rather run a tube down to the tail of the plane and have the antenna exit the aircraft there. Does it make a difference? I'm guessing no, but wanted to double check.
Thanks guys!
