more
When you are done it should slide back into the hinge points, and move freely over the whole range of motion. You will probably have to keep sanding a bit to get it to move freely, but be careful, the wood is hard to put back. The more sweep the trailing edge the harder it will be to get the surface in and out, so be patient.
