RE: Aileron Reflex
PropSpinner,
Most computer transmitters have flaperon capability. Just use that in reverse or use negative values or whatever. Obviously each aileron servo must be on a seperate channel. You program them into a switch on your transmitter. The spoilerons will try to force your nose up as if you were tail heavy. It is really exciting flying when you don't realize they are on, especially if you try to roll.
